Solar power down
Solar power down
Postby Haggie » Fri Dec 31, 2021 7:37 am
As of last nigh our solar system has not seen the sun for to many days and has turned it self off due to low battery levels. When the sun comes back out I am hoping it will come back on by itself.
Re: Solar power down
Postby Haggie » Sat Jan 01, 2022 5:49 pm
The solar power is still out at the field. We still have not seen the sun.
Postby Haggie » Tue Jan 04, 2022 5:05 pm
I was at the field today. The problem is with our router. Spectrum is scheduled to come out on Thursday. Until then there will be no cameras or internet. I will update on Thursday.
Postby Haggie » Thu Jan 06, 2022 4:00 pm
Spectrum installed a new router and modem today at the field. I could not get the cameras to link. We will have to wait for Nancy to get to the field with her lap top to reconnect the cameras to the new router.
Postby admin » Wed Jan 12, 2022 12:37 pm
Update: Since we have a new router remember when you are at the field to reconnect your WiFi otherwise you will be using your data. WiFi password is posted on the bulletin board. It’s the same. Camera are up and running. You can click on the links for the cameras under members only section. Must be signed in. If you have the links saved elsewhere update them.
