The clocks have changed one hour ahead for Daylight Savings Time. If your clock on the website is not showing the correct time, here is what to do.
* sign in / * on the upper right side of the forum page click on Board Index / * choose the Board Preferences Tab / * you will be in edit global setting / * your timezone should be UTC-5 Eastern Standard Time / * Summertime / DST is in effect should be clicked "yes" / don't forget to click "submit" at the bottom of the page.
