Camera and WiFi Update
Postby admin » Wed Jan 12, 2022 12:37 pm
Update: Since we have a new router remember when you are at the field to reconnect your WiFi otherwise you will be using your data. WiFi password is posted on the bulletin board. It’s the same. Camera are up and running. You can click on the links for the cameras under members only section. Must be signed in. If you have the links saved elsewhere update them.
