Storm Damage
Storm Damage
Postby admin » Sat May 10, 2025 7:08 am
You may have noticed the Davis Weather Station and Nest Cameras are not working right now. Due to a storm the other day our inverter and router were damaged. John has replaced the inverter. Most of the solar panels were damaged as well. We won’t know until the internet is back up and running if the cameras or weather station were damaged. As of now the weather station is transmitting to the base unit but don’t know if the cable that transmits to the internet was. He will make an appointment with Spectrum to replace the router.
Please be aware if you are at the field you will be using data from your provider on your devices until everything is remedied. Thank you for your patience.
