by Mike55 » Wed Jan 19, 2022 12:32 am
Putting considerable time into this plane, not much progress to show for it.
Cutting old hinges, drilling them out & reassembling control surfaces takes time if its to be done right.
Found out that the best way to cut old hinges is with a nice new, sharp #2 Xacto blade in a HD handle.
Steady pressure and a rocking motion cuts cleanly through the hinge.
A dremel with a tiny saw blade or a grinding disc just melts through the hinge, leaving a mess.
Compared to the drill press, the cleanest, most accurate holes i made were by hand.
Started with a tiny bit in a pin vise, & gradually increased size to what was needed.
With the drill press, the bit would flex a little bit & be off center.
- Attachments
![20220117_231103.jpg (43.31 KiB) Viewed 1829 times 20220117_231103.jpg](./download/file.php?id=1374&t=1&sid=e70c8c9e9d6af56d28b7ad81cf5851fd)
- Aileron gaps aren't that bad, might leave them.
![20220118_210457.jpg (131.63 KiB) Viewed 1829 times 20220118_210457.jpg](./download/file.php?id=1372&t=1&sid=e70c8c9e9d6af56d28b7ad81cf5851fd)
- With tail feathers removed
![20220118_232900.jpg (54.1 KiB) Viewed 1829 times 20220118_232900.jpg](./download/file.php?id=1371&t=1&sid=e70c8c9e9d6af56d28b7ad81cf5851fd)
- Rudder back on, taped while epoxy hardens
