Redwing MXS-R
Redwing MXS-R
Postby Mike55 » Thu Jan 13, 2022 12:20 am
Originally posted under General Discussion titled: Merry Christmas to ME!!
Decided to put it under Project Builds and add pix as I work on it.
Here are the original pix the day I brought it home:
As I stated in my original post, the original owner glued the control surfaces with HUGE GAPS!!
That is the first issue I am addressing.
Re: Redwing MXS-R
Postby Mike55 » Thu Jan 13, 2022 12:43 am
Starting to address the hinge gaps.
Have new hinges and a drill guide Gizmo coming.
Hopefully I can drill out the old hinges & replace them.
The hardwood blocks inside the structures are too small to relocate the hinges, Sooo... I'm gonna have to drill out the originals.
Also have servos, pull-pull cables, & other bits & pieces ordered.
Power will be a DLE 30 (Thank you Henry!!)
We don't need no stinkin Wheel Pants!!
Horizontal Stab & Elevator separated.
Now That's a Hinge Gap!!
Re: Redwing MXS-R
Postby Mike55 » Fri Jan 14, 2022 12:03 am
Got some more STUFF today.
Harbor Freight drill press. (Will drill straighter holes than I could by hand)
Also got a V-Block for it to hold rounded pieces.
And the hinges & other stuff showed up, so tomorrow i can start trying out the drill press. :o
Needed this to drill the old hinges
The assembled Drill Press
Assorted Goodies
Re: Redwing MXS-R
Postby Mike55 » Wed Jan 19, 2022 12:32 am
Putting considerable time into this plane, not much progress to show for it.
Cutting old hinges, drilling them out & reassembling control surfaces takes time if its to be done right.
Found out that the best way to cut old hinges is with a nice new, sharp #2 Xacto blade in a HD handle.
Steady pressure and a rocking motion cuts cleanly through the hinge.
A dremel with a tiny saw blade or a grinding disc just melts through the hinge, leaving a mess.
Compared to the drill press, the cleanest, most accurate holes i made were by hand.
Started with a tiny bit in a pin vise, & gradually increased size to what was needed.
With the drill press, the bit would flex a little bit & be off center.
Aileron gaps aren't that bad, might leave them.
With tail feathers removed
Rudder back on, taped while epoxy hardens
Re: Redwing MXS-R
Postby muzamilabbbasi » Tue Jan 10, 2023 1:06 am
nice progress
Muze
muzamilabbbasi
Stunt Pilot
Users browsing this forum: No registered users and 0 guests
