Solar Generator
Solar Generator
Postby Haggie » Sat Mar 05, 2011 8:25 am
I have been working on a project for the field so we can charge our batteries at the field.
This is a picture of the charging box.
IMG_4852 (Small).JPG (70.59 KiB) Viewed 6349 times
IMG_4853 (Small).JPG (37.23 KiB) Viewed 6349 times
Re: Solar Generator
Postby nalby » Sat Mar 05, 2011 9:04 am
Looks Great. How many amps will it put out?
nalby
Re: Solar Generator
Postby Haggie » Sat Mar 05, 2011 5:14 pm
At this time it is backed by two 30 amp circut breakers. the red line down the middle of the box is the split of the circuts
Re: Solar Generator
Postby Sal A » Sat Mar 05, 2011 11:15 pm
Looks great- and remember if the video cam can work out , I'll provide it.
Sal A
Re: Solar Generator
Postby Haggie » Sun Mar 06, 2011 8:01 am
Here are more pictures of work in progress
At this point the charging shelf and box have been installed.
Bellow the brackets for the solar panels are mounted on the roof
Re: Solar Generator
Postby Haggie » Sun Mar 06, 2011 8:11 am
The next move is to install the solar panels on to the mounting brackets.
Now we install the batteries. The charging station is now completly installed
at the field and is usable for charging. Enjoy.
Re: Solar Generator
Postby Pingber » Sat Mar 12, 2011 12:05 pm
You gonna post instructions for use?
Pingber
Re: Solar Generator
Postby phjoker » Sat Mar 12, 2011 1:18 pm
Pingber wrote:You gonna post instructions for use?
Plug the banana plugs from your charger into the Grey box with all the Fe-male banana plugs.
Turn on your charger and charge your battery per the manufactures instructions.
All that is being supplied is 12V for your charger. If for some reason your charger is not on once plugged in Press the re-set button on the box. :shuffle
**Can You Smell The Jet Fuel Burning**
phjoker
Re: Solar Generator
Postby blackbird » Tue Mar 15, 2011 7:56 am
What, no leads? You mean I have to provide my own long leads? :grin
Thank you John and all of you who have gone through the trouble of getting this charging station from idea to a working, functional charging facility.
I am sure it will get as much use as the flight line.
Re: Solar Generator
Postby phjoker » Tue Mar 15, 2011 9:23 am
I took a 25 foot long 12gauge extension cord and put banana plugs on on end. The other end I have a 4"x2" plastic box with 2 sets of female banana plugs on the box. Now I can be 25 feet away and still be able to use the charger.
If any one want pictures let me know.
I am also in the process of making a 4 foot long extension with the banana plugs If you look haggies pictures you can see the table is about 6 foot long. Chargers only come with about 3 foot of cord.
phjoker
